New Pside-kick fittings
Rainier
wyoming
Hi Folks,
I received my new Pside-kick unit last month and am preparing to install it in the cabin.
My question is about what fittings to use with the CSV1A valve since it is stainless steel and the older model used the CSV1W which was bronze.
When I connect it to my water system do I need to use stainless steel fittings or can I use brass?
I was thinking of maybe stainless nipples in and out of the valve and then brass fittings for the shut off valve and drain faucet. The other option ,I guess, would be to go with galvanized steel.
What have you folks done?
Thanks,
Rainier
Craigpump
Why did you do say with the csv1w? Did it fail or wear out?
You can use sch 80 pvc nipples and bushings to insulate the cast iron from the stainless steel.
Rainier
wyoming
Thanks craigpump,
The csv1w was shown in the catalog that I had and has been replaced with the csv1a. The kit in my older literature also had a brass manifold and some pieces not included in the new model.
Rainier
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
What kind of plumbing do you already have? Plastic, Pex, SS, Brass, or galv, it won't make much difference as any of it will attach to the CSV1A. Galvanized is the only one that might eventually corrode.
Rainier
wyoming
Hi valveman,
This is new construction.
My concern was corrosion caused by dissimilar metals.
So, I'm OK with using brass fittings to connect my valve into my system ?
Rainier
