new kitchen circuits
Discussion in 'Electrical Forum discussion & Blog' started by wallygater, Oct 17, 2009.
  1. wallygater
    wallygater New Member
    Dec 16, 2007
    long island
    How many new circuits will I need for my kitchen remodel?
    microwave= dedicated 20 amp
    refrigerator= dedicated 20 amp
    gas stove, outlets, switches, lighting, fan, toaster oven = dedicated 20 amp
    That's three
    Do I need another one for the dishwasher?
  2. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    The NEC requires a minimum of 2 20-amp circuits to serve the receptacles. There can be no lighting on these circuits. Microwave hoods will require a dedicatd circuit. Some refrigerators will require a circuit, otherwise can share the 20 amp small appliance circuit. Gas ignitors can also share the small appliance circuit.
    Dishwashers and disposals can sometimes share a circuit.
  4. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    As stated above with my own twist:
    2 - 20 Amp circuits for the kitchen counters (mandatory) & gas stove receptacle
    1 - 15 Amp circuit for the fridge (most only use 7-10amps)
    1 - 20 Amp circuit for the built in microwave/exhaust hood combo
    1 - 15 Amp circuit for kitchen lighting and miscellaneous wall receptacles.
  5. jimbo
    jimbo Plumber
    Refrig, micro, DW. Each works on a 15 amp. A dedicated for each is very convenient, because you can turn off just that one for service if necessary; and of of course each uses the better part of 15, so you would not want to combine.. DW used to be typically hard wired. I don't know it code requires plug in now, but I can tell you that the new tall tub DW are much more difficult to work with, and having a cord to an outlet in the adjacent undersink cabinet makes that part of the job easier.
  6. hj
    outlets
    HAving a cord to the sink cabinet also provides for a "visible" disconnect means when working on the dishwasher. What are "miscellaneous outlets" on a lighting circuit?
  7. wallygater
    Dec 16, 2007
    long island
    I would like to keep the lighting and the "miscellaneous outlets" on a seperate circut.
    "2 - 20 Amp circuits for the kitchen counters (mandatory) & gas stove receptacle"
    I will only have one counter outlet so I guess that means just one manditory 20 amp breaker, not two
    Does that sound correct?
    lights 20 amp
    fridge 20 amp
    counter outlet 20 amp
    microwave 20 amp
    dishwasher 20 amp
    miscellaneous outlets 20 amp
    Thats 6 new breakers in the box. Does that sound like to much?
  8. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Kind of....maybe. In some cases there is no such thing as too many. If the space is available and the access is easy, the more circuits, the less the load is on each circuit. In my house I installed 4 circuits just for the counter top receps. That way there is no worries if a coffee pot gets plugged in next to a toaster.
    Your kitchen must have two 20 amp circuits for "small appliances".
    Your built in micro must have one 20 amp circuit
    Your dishwasher/disposal must have one 20 amp circuit.
    The refer can be on one of the counter top recep circuits. Run the home run to the refer first, then to the counter top recep. Refer doesn't have to be GFCI protected (and shouldn't in my opinion).
    We generally put the lighting on an existing 15 amp circuit.
Similar Threads: kitchen circuits
Electrical Forum discussion & Blog Kitchen in basement - two circuits May 9, 2016
Electrical Forum discussion & Blog New Kitchen Circuits Using 12-3 Jul 23, 2007
Electrical Forum discussion & Blog Question on 3-wire Kitchen Range > 4 wire Nov 24, 2016
Electrical Forum discussion & Blog Dedicated circuit kitchen rule for wet bar? Jul 4, 2016
Electrical Forum discussion & Blog Kitchen Island install Dec 28, 2015
