hey all, I come asking for help. I had a softener installed a few years ago and need help figuring out how to set the timer. Unfortunately asking the plumber/installer is not possible. I have noticed a lot of scale and other stuff that is making me think it isn't set correctly.
I am pretty sure it is a Fleck 2510 econdominder valve (see pics). I have the manual, and also looked online for everything I can find about it, and for some reason it just doesn't make sense to me. From what I am reading, it says to turn one dial for the number of people, and turn another one for the water hardness, but I think I only have one dial to turn. The clear dial that I can bull and turn has the little people icons/numbers on it, and also numbers from 0 to 21 on it, all on the same dial. So I am not sure if I turn the knob so the number of people (2) lines up with the white dot? or set the number to grains of hardness (23 ) or is that telling me gallons? And I know I can pull the clear dial out, and the dial behind it will turn too, do I set that to something? etc.?
Here are a couple pics, if someone could help me out, I would really appreciate it. I am pretty sure it is a 48k system, the tank is about 5' tall if that helps. If you need more info, I will do my best to let you know. Thanks much,
Brew
Brew
