Natural gas outlet for BBQ
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mad Plumber, May 8, 2006.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    I just bought a Weber Natural Gas barbecue. I need a 15-foot flexible hose to connect it to my natural gas outlet across my yard. HELP!!
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Check with a deal to see if they have a flex hose that long. Is it possible to run a pipe to the location? When I install my gas BBQ, I put two outlets, one under a breezeway and the other in the open. However, I was able to run the pipe under my deck so all I need for hose is the 12' length that came with the unit. I would presume it would be possible to have a hose made up with the quick couplers. The gas company might have some ideas also.
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I was just thinking about doing this while I have access to the backyard in my not yet finished kitchen remodel.
    I would run black iron pipe and use flex for only a short distance. Sure it makes you less flexible in placement (ha! get it?) but I bet its more durable. My local Ace had all kinds of lengths of flex pipe. Check there?
    Jason
  5. jimbo
    jimbo Plumber
    I don't actually know if any code restricts the length of a flex line outdoors. Indoors you certainly can NOT use 15 feet. As a practical matter, for safety you should not use such a long hose. Extend the hard pipe to within reach of a 4 or 5 foot hose.
  6. jadnashua
    One thing to be aware of is the national code regarding grills has changed and is being adopted by towns and cities across the country. It severly limits the use of propane in many situations and has some specific provisions regarding natural gas grills as well. The restrictions are much more severe over multi-family dwellings, but single family ones are still potentially impacted. For example, they want the grill at least 10' from the house or an attached deck.
  7. hj
    gas
    I hope you would not be running that black pipe underground, and in many areas if it is above ground outdoors it has to be galvanized.
  8. Lakee911
    Aug 23, 2005
    Columbus, OH
    Do you install the black iron pipe in a sleeve or conduit/duct or something to go outdoors? What does the gas company use for incoming line when its not plastic? Looks like black (rust color) iron pipe.
    Jason
  9. jimbo
    jimbo Plumber
    Outdoors above ground, some areas will require you to use black pipe and wrap or paint it. Some areas will require galvanized. Underground, galvanized used to be used a lot, but is no longer accepted. Here, the green epoxy coated is the norm, but failure to properly wrap the joints will also cause failure of that. Plastic pipe, which cannot be installed by homeowners, will eventually replace steel pipe in the codes I believe.
  10. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    Another thing to keep in mind depending on which building code you fall under.
    If you run gas out to your deck and the deck is covered, a sprinkler head is required.
  11. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    to jadnashua
    never thought about a barbacue or grill on a 2nd story condo deck. if it was against wood siding, that would be scary :eek:
Similar Threads: Natural outlet
Plumbing Forum, Professional & DIY Advice Run natural gas to kitchen island - details Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Adding gas range and outdoor grill. Do i need a new natural gas meter? Sep 7, 2016
Plumbing Forum, Professional & DIY Advice Natural Gas leak outside of house May 13, 2016
Plumbing Forum, Professional & DIY Advice Natural Gas Line Pressure Test Mar 22, 2016
Plumbing Forum, Professional & DIY Advice Water heater - natural gas - black iron rebuild with flexible CSST Feb 16, 2016
