Moving outdoor faucet
Discussion in 'Irrigation / Sprinkler Forum' started by NEWFREDDY, Apr 22, 2006.
    NEWFREDDY New Member
    Apr 22, 2006
    I currently have an outdoor faucet near the back of my home. I want to move the faucet nearer to the front of the house. Is there an easy way to do this? I was hoping I could attach something to the faucet and run it to the front and bury it just under the surface of the yard. I realize I would have to make sure it is drained in the winter so it will not freeze but do not want the expense of making a complete connection from the main water supply to the front of the house. I was hoping there was a fixture I could either mount on the house or in the ground at the new location.
    Any help would be appreciated.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Get the following parts:
    1. One length of reinforced hose that is designed to be constantly pressurized.
    2. One double hose adapter with valves to go on your existing faucet (get rid of the space after the www)
    3. Hose adapter, valve, and fitting to meet your "front of house" needs for mounting.
    If I were doing it, instead of the hose, I would use a piece of 3/4" black poly pipe or 3/4" PVC (my preference) to run around the outside from the faucet. Then add your faucet out front.
    CAUTION: This arrangement, and anything else you bury, is probably a violation of backflow prevention regulations. If you are on your own water system, you are the only one at risk. If you are on a municipal system you should worry about others. You need at least a vacuum breaker on the first faucet.
    Apr 22, 2006
    Bob, thanks for the info.
    I have decided not to bury anything but just run a line to the front of the house. When closing up for winter I will be able to move everything inside and then move it back outside in the spring.
    Thanks again
Similar Threads: Moving outdoor
Irrigation / Sprinkler Forum Moving water 600' up hill Jul 30, 2011
Irrigation / Sprinkler Forum Removing sprinkler heads Jun 8, 2011
Irrigation / Sprinkler Forum Need Help Removing Impeller from Goulds JS+ pump Jan 25, 2010
Irrigation / Sprinkler Forum drain valve and removing water Jul 7, 2008
Irrigation / Sprinkler Forum Moving an inground sprinkler head Jun 11, 2007
