Moen single control bathtub/shower faucet leak
Discussion in 'Shower & Bathtub Forum & Blog' started by gmrsich, Apr 14, 2007.
  1. gmrsich
    gmrsich New Member
    Apr 14, 2007
    Good Morning,
    I have a slow, but steady drip coming from my bathtub nozzle controlled by a single, pull-out, Moen faucet. Removing the cover plate, I assume that I will have to "unscrew" the nut surrounding the pull-out stem and replace a washer of some sort.
    Can some wonderful soul advise?
    Thanks,
    George:D :D
  2. jimbo
    jimbo Plumber
    A typical Moen shower does not have any nut to unscrew. Under the handle, if you see a sleeve with a "bump-out" on it, pull that sleeve out. Then you will see a tiny hole in the top of a horshoe clip. Turn off the water, and pull that clip out. It is what secures the cartridge in the body. You may then need special moen cart. puller to rotate and loosen the cartridge before pulling on it. Post a picture here for more details.
  4. gmrsich
    gmrsich New Member
    Apr 14, 2007
    Thanks Jimbo...I'll be awhile before I can post the picture. I have 21-month-old triplet boys to tend to with wifey! Your description of the clip fits my setup though.
    George:D :D
Similar Threads: Moen single
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen single handle shower is slow to fully start and slow to stop Dec 28, 2015
Shower & Bathtub Forum & Blog Increasing the flow rate of a Moen Voss Voss-Single-Handle-High-Arc-Lavatory-Faucet Sep 27, 2013
Shower & Bathtub Forum & Blog Alignment of Moen plaster ground (single handed shower faucet) Apr 30, 2013
Shower & Bathtub Forum & Blog Hot/Cold Reversed on Moen Single Handle Shower Knob Apr 15, 2012
