Moen Posi-Temp 1222B Shower Cartridge
Discussion in 'Shower & Bathtub Forum & Blog' started by SteveMar, Aug 11, 2011.
  1. SteveMar
    SteveMar New Member
    Aug 22, 2009
    Maryland
    In March 2011, we had our bathroom remodeled, and our new Moen shower fixture takes the 1222B cartridge. I know this because it leaked and I replaced it twice in the first month. I thought the third try would work out, but after four months the cartridge has again begun leaking and the tub spout is again dripping. I am sort of disgusted with this product, and am tired of replacing this over and over. I am using Moen parts, not aftermarket. My questions are--have others run into this sort of performance problem, and is there a better replacement product available than the 1222B? Thanks!
    [​IMG]
  2. jadnashua
    It's possible that there is a scratch in the body, and no cartridge is going to last long. Have you talked to Moen? In most cases, they'll send you a free cartridge.
  4. SteveMar
    SteveMar New Member
    Aug 22, 2009
    Maryland
    Jim
    Moen has sent me a couple free cartridges, and will probably send me another one in this instance. Free cartridge aside, it seems like a cartridge should be able to function correctly for more than 1-4 months.
  5. jadnashua
    As mentioned, if there is a scratch in the body of the valve that the cartridge fits into, that can abraid the seals and they won't last long. The only fix on that is to replace the body and the cartridge. Make sure that if there isn't any silicon plumber's grease on the cartridge, you put some on before inserting the new one. This will make it both easier to insert and help it last a little longer.
Similar Threads: Moen Posi-Temp
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp Valve Identification Jul 16, 2016
Shower & Bathtub Forum & Blog Moen posi-temp problem Apr 1, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp Banbury Model One Handle Tub/Shower Faucet - New install, hard to turn Feb 1, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp Valve Uses No Backing Board? Dec 16, 2015
