Mobile home inspection
Spfrancis
Virginia
I am looking at purchasing a mobile home on a lot that is pretty nice, and I want the lot. I need the mobile home to be okay for 5-7 years. It was built in 1988, so pretty dated. The one item that the inspector pointed out was some patch work, or something that was done to support the base of the mobile home.
Here is a pic of it:
I'm not sure if these types of changes are normal for a mobile home. Any thoughts?
James Henry
Billings, Montana.
Stack some blocks on a stable footing like the other masonry blocks are and use wood shims to wedge the blocks under the trailer joist then remove that stack of blocks. blocks aren't meant to support weight when their resting on their ends, they could collapse.
Spfrancis
Virginia
thanks for the feedback. It sounds like it really isn't a bid deal, but should be fixed.
Clarissa7
NY
During a mobile home inspection, always check under every exterior window, as well as on the entire interior perimeter of a mobile home.
