Metal roof flashing--best one?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mr Russ, Aug 23, 2012.
  1. Mr Russ
    Mr Russ New Member
    Jul 31, 2012
    machinist
    LA.
  2. ballvalve
    Dec 28, 2009
    northfork, california
    First, I think one absurd thing builders do is pepper roofs with hundreds of UGLY vents and pipes. One small house near me has 16 piece of junk out the roof, everyone a future leak. One 3" pipe will handle most houses, and certainly one 3" hole is cheaper than 16. And you can go out the sidewall, if you follow the code. Then we use fire stop eave vents and a continous ridge vent. A perfect roof.
    I use that roof, and its a problem. go out the sidewall after talking to the inspector, tie vents in the attic. NOt possible - I have made a tight hole with a hole saw and used a small steel or neoprene ring [like the top inch of that pic] and super siliconed in, under, and around it and then used some elastomeric mastic over it all, and painted it to match the roof. stay off the ribs. fiberglas tape in the mastic makes it bombproof
  4. Mr Russ
    Mr Russ New Member
    Jul 31, 2012
    machinist
    LA.
    I dont have any gables on my house. So when you say sidewall is that what you are referring to?
  5. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    One of the places I plumb is S.F. The S.F. amendment to the U.P.C. requires at least one plumbing vent to have the same aggregate area as the lateral. So a 4 " vent is mandatory. I also roof ,have 2 hot tar kettles. Go to a roof supply that sells standing seam roofing,they will set You up with the proper flashing. Of course weather You have the skill and experience is another thing ! I still have my ZAX [ slate hammer] from doing slate roofs in Boston 1962. Good luck
  6. hj
    IF you have a "guaranteed roof", then the roofer usually INSISTS that they do the pipe seals so there is not question about liability in case of a leak.
  7. ballvalve
    Dec 28, 2009
    sides, gable end, any wall. Here, houses have 3" abs tying to the septic 4" outside, so its considered 3" is the size for the house.
  8. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    I was fortunate to start the trades in New england. 1st work was a roofer. $7.05 a square for bird shingles. Learned the proper way to flash,with copper,
    and lead. When I came West I couldn't believe what i was looking at on some roofs !
  9. ballvalve
    Dec 28, 2009
    I agree. Lead is the best, but the chinese have tripled the cost. I used to do copper roofs - copper at $1.78 a pound - Now scrap is at 3$+ . Few on the west coast know anything about flashing. I see it lapped the wrong way, and even missing. Maybe some caulk. Just built a "gypsy wagon" and used copper foil, which is still reasonable and durable. Maybe I'll post a picture later.
  10. ballvalve
    Dec 28, 2009
    Here is a real roof and a forever "motor home" . Made the papers and the owners published a book on it. You should see the interior.....
Similar Threads: Metal roof
Plumbing Forum, Professional & DIY Advice Metal roof- vent flashing, small ones for 2" & 1.5" Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Metal Roof PVC standpipe is loose Feb 22, 2010
Plumbing Forum, Professional & DIY Advice Venting through metal roof Apr 30, 2008
Plumbing Forum, Professional & DIY Advice Installing a new faucet, pressure seems too high going from Flowtite piping into new metal piping Mar 15, 2016
Plumbing Forum, Professional & DIY Advice FALLING DOWN c1966 rimless undermount sink, clips to metal bezel Jul 29, 2015
