manabloc with master shower
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by freebird_wr, Dec 7, 2010.
  1. freebird_wr
    freebird_wr New Member
    Feb 23, 2007
    Hello,
    I am in the process of installing the plumbing for our new master bath. We will install a Manabloc manifold with a 1/2" PEX going to the shower. We plan on using a Moen shower setup with a showerhead, diverter and 4 body sprays. Is there anything we can do to make sure we have adequate pressure?
  2. jadnashua
    You'll need bigger than 1/2" pex for that.
  4. freebird_wr
    Feb 23, 2007
    Can you run 3/4" from the Manabloc or is there another way to do it?
  5. jadnashua
    If the Manbloc has 3/4" ports, run that, or even 1". You can convert it to the valve side when it gets there. Just upsizing the pipe if the port is small will help, but it's not the same as having a larger port. Keep in mind that pex has a smaller ID than copper, PLUS, the fitting fits inside of it, further reducing the max flow.
  6. DirtyDen
    DirtyDen New Member
    May 3, 2011
    Plumbing and Mechanical
    Colorado
    High Volume fixtures
    I realize this is a bit late as you are most likely beyond the changing point, but for those who may have similar questions in the future. The easiest solution is to run two 1/2" lines and use a bullhead tee (1/2x1/2x3/4 tee). This generally supplies enough water for those high volume fixtures (not the eight headed monster). As stated in prior posts, pex does have a narrower id (inside diameter); however, if installed as a homerun (not exceeding the specified lengths), the elimination of fittings more than overcomes this restriction. Every change of direction adds to the pressure drop in the line regardless of material. With pex, there is no change in direction (unless fittings are used). So, if you are using pex in a traditional method (2 pipe/branch&tee), be sure to look at the charts to determine if you can get there with 1/2".
    There are no 3/4" or 1" port on the Manabloc.
    P.S. this also is the solution for large tubs.
Similar Threads: manabloc master
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
Plumbing Forum, Professional & DIY Advice Manabloc supply lines blow off Feb 19, 2016
Plumbing Forum, Professional & DIY Advice use a manabloc yes or no Mar 19, 2013
Plumbing Forum, Professional & DIY Advice Goodbye PB hello PEX + manabloc Aug 20, 2012
Plumbing Forum, Professional & DIY Advice Pex Vanguard Manabloc manifold ... which type and diameter? Feb 17, 2012
