Main stack pipe leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Annie62, Jan 6, 2013.
  1. Annie62
    Annie62 New Member
    Jan 6, 2013
    Ontario
    I don't know if this is the correct name for this pipe, but it is a big, black plastic pipe that ends up in the basement and goes under the concrete. There is a round disc on the side of the pipe and it is tight so I pretty sure the water is not coming from there. It is not a lot of water - more a weep but enough to make the carpet around it in our finished basement wet - i wonder if it is the connection that is not good. We did have a problem earlier this fall where the basement was wet coming in from the exterior wall. The carry-away pipe on the outside drain pipe had come off and we had had a lot of rain. I don't think this the same issue. Any help would be appreciated ....cash is tight.
  2. hj
    That should be a cleanout, and if the plug is tight it should not be the source of the leak, UNLESS it is so tight that the opening around it has a crack in it. Otherwise, that type of pipe system should not have any leak in it.
  4. Annie62
    Annie62 New Member
    Jan 6, 2013
    Ontario
    Thanks for your quick response. What do you mean by "cleanout"?
  5. hj
    If you have a sewer or drain problem that "cover/plug" is removed by the plumber and he uses the opening to "clean out" the stoppage using his equipment.
  6. Annie62
    Annie62 New Member
    Jan 6, 2013
    Ontario
    I have noticed that my dishwasher bubbles through the sink when draining - could this be a symptom too?
  7. hj
    Not likely. That is a different problem, although that could just be the way it is connected.
  8. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    Besides the color difference is this what your stack looks like?
  9. Annie62
    Annie62 New Member
    Jan 6, 2013
    Ontario
    Yes! Although the round thing is closer to the ground. Thanks - will wait for your response
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    From your description, it does appear that this is you main drain stack and the "disc" is the cover for the clean-out. If the pipe is plastic, it is ABS which is made from different chemicals than PVC, but is commonly used for drains. As noted, the cover screws into the tee, and it could be loose. It is also possible that the tee has a small crack. I would suggest you monitor this closely and try to determine where the water is coming from. If it is a cracked fitting or while unlikely, a bad joint, it would be a job for a plumber. There is no dependable patch than can be applied to PVC or ABS, it requires replacement. Not a real difficult job for a plumber, but for a novice DIY, you could find yourself in trouble and have to hire a plumber anyway. I realize cash is a problem, but sometimes it's cheaper in the long run to get a professional in the beginning. Look especially carefully around joints where the pipes are connected either to another pipe or to the tee fitting with the plug. If it is leaking around the plug you might try tightening it, but don't overdo the force. The bubbling at the DW could be the signal that the drain needs to be cleared and that requires a plumber too. Don't just pour liquid drain cleaner into it. They don't work or real clogs.
  11. Annie62
    Annie62 New Member
    Jan 6, 2013
    Ontario
    The water is coming from the upper join in the outer casing just above the disk. You ca see the red paper arrow pointing at the water. Hope this helps. Thank you
  12. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    If the water isn't running down the pipe and just ending up on that joint, it means that your pipe is probably clogged and they also didn't do a good job gluing that joint. If this is the case, that whole pipe could be filled with water.
    The cap could be removed and that line could be snaked (I would get a pro for that). However, you will need something ready to catch the water as there could be several gallons sitting in that pipe (or may not depending on the clog and how much that drain gets used). If you were going to open it and clear yourself, I would probably wait a couple days and not use anything that might drain into that stack. This should allow the water to drain unless it is 100% clogged. You would still want to be ready with something to catch the water (and may be nasty stuff with kitchen and toilet waste in there, so be prepared).
  13. Annie62
    Annie62 New Member
    Jan 6, 2013
    Ontario
    Thank you. Doesn't all the waste come through this pipe? All the bathrooms are on the same side of the house so I am wondering if it is maybe hair clogging it. How much doe you think this would be? Also would a cleanout still be neccesary? Thank you everyone for your advice - it has been a real education!
Similar Threads: Main stack
Plumbing Forum, Professional & DIY Advice Main Stack as vent for tub and shower drain Mar 8, 2017
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cold water supply line connected to cast iron main stack? Oct 27, 2016
Plumbing Forum, Professional & DIY Advice Toilet drain to merge in offset part of main stack? Aug 10, 2016
Plumbing Forum, Professional & DIY Advice Main Stack leaking May 26, 2016
