LUX TX9000TS Thermostat. Made AC run all night long.
Discussion in 'HVAC Heating & Cooling' started by thinkly, May 23, 2011.
  1. thinkly
    thinkly New Member
    May 21, 2008
    Kansas
    I have a LUX TX9000TS that is about two years old. I have never had any trouble with it till lately. The first time I switched it to AC this season it seemed like it didn't want to kick the AC on, although it eventually did and then continued to operate normally for several days.
    The weather cooled and I turned the AC off. Fast forward to last night and it was hot again. Before bed I switched the Thermostat to AC and went to bed. I woke up at 5 AM and the house was like a refrigerator inside.
    I went out to the thermostat and discovered the display was blank and again the AC is still running, 7 hours after i turned it on. So i opened the thermostat, replaced the 2 AA batteries and the display worked fine again.
    Is this normal to have this happen when batteries fail in a programmable thermostat?
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Hello thinkly,
    There should be a 'replace' icon, that tells when the battery is low.
    If the battery voltage is low enough then it may not be able to Toggle the relay, and just stays in the last position that it was in.
    I would say that would be normal.
    Also the colder the battery gets the lower the voltage, so air temp becomes a factor on weak batteries.
    Have a Great day.
    DonL
  4. MAoilTech
    MAoilTech New Member
    Nov 24, 2009
    Oil Tech,HVAC
    MA
    try running ur ac again pull the tstat from its base does it shut off the unit? if so good if not you got a bad issues.
Similar Threads: TX9000TS Thermostat
HVAC Heating & Cooling Aprilaire 700 humidifier with Nest thermostat Feb 9, 2017
HVAC Heating & Cooling Recommend A Thermostat? Feb 8, 2017
HVAC Heating & Cooling Relocating thermostat to allow heating with wood stove? Jan 17, 2017
HVAC Heating & Cooling How to control the heat using the thermostat? Nov 20, 2016
HVAC Heating & Cooling Thermostat won't power on Oct 30, 2016
