Lowboy under countertop
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by justinae, Nov 7, 2011.
  1. justinae
    justinae New Member
    Sep 20, 2010
    Portland, OR
    I've got a project converting a garage into a studio apartment. When the design was originally done we were going to use radiant heat so the architect never spec'd out a place for a hot water tank. That has now changed and we need to find a place for it. Right now the plan is to put it under the kitchen countertop. It's an outside corner next to an exterior wall so it won't be competing visually with other cabinets. Here are the tanks we're considering:
    AO Smith ECL-50
    Whirlpool E2F50LD045V
    American E62-50L-045DV
    Reliance 6 50 DOLS
    GE GE47S06AAG
    The American has the best specs at 31 5/8" tall by 24" in diameter. I'm concerned that there won't be enough room to make the connections to the supply lines. I'm assuming the dimensions are just for the tank and not the supply stubs.
    Anyone ever install one like this before?
    thanks,
    Justin
  2. jimbo
    jimbo Plumber
    Electric water heaters could be condsidered a commodity, like pork bellies. Not much real difference from one to the next. Yes, the pipes almost always come off the top.
  4. justinae
    justinae New Member
    Sep 20, 2010
    Portland, OR
    Yeah AO makes one that comes out the sides but it's only 38 gallon. I think we'll go with the American just for being the shortest. We'll just have to have a 90 degree fitting coming right off the tank.
  5. hj
    What is the connection between radiant heat and a hot water tank? They serve two different purposes. One is for space heating, and the other is for "cleaning" uses.
  6. justinae
    justinae New Member
    Sep 20, 2010
    Portland, OR
    out here radiant floor heat is often connected into the potable water supply.
  7. hj
    quote;
    Exactly, therefore, it WOULD have needed a hot water heating unit of some kind, to supply BOTH needs.​
  8. justinae
    justinae New Member
    Sep 20, 2010
    Portland, OR
    original design had gas on demand unit for both radiant and potable hot water. without the radiant floor, and subsequently gas, we need an electric water heater.
Similar Threads: Lowboy under
Plumbing Forum, Professional & DIY Advice Which Electric Lowboy? Apr 8, 2012
Plumbing Forum, Professional & DIY Advice Kohler lowboy rebuild tips&tricks needed May 30, 2007
Plumbing Forum, Professional & DIY Advice Lowboy gas waterheaters. Apr 22, 2007
Plumbing Forum, Professional & DIY Advice Can't Find Lowboy Gas Water Heater Jan 21, 2005
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
