low water well pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by billrcpilot, Mar 18, 2012.
  1. billrcpilot
    billrcpilot New Member
    Mar 17, 2012
    Retired USAF
    Crescent, Oklahoma
    i have a shallow well 22 ft. 1hp jet pump, square D pressure switch set at 40/60 psi and 10 gal bladder tank, i'm able to build pressure up to 60 psi then pump stops but when we use water to the house or try to water lawn pressure drops to 20 psi and will not build any higher, what could be the problem.:confused:
    Thanks Bill
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Sounds like you are getting all the water there is in the well. Maybe your well screen is plugged up.
  4. billrcpilot
    Mar 17, 2012
    Retired USAF
    Crescent, Oklahoma
    I have been told that the well casing my be fill with sand that came thru the preferated hole in the casing, if so i would i get it cleaned out,
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    You will need to fix the hole in the casing to keep the sand out.
  6. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    I have a cousin that lives North of Crescent! Does your well have a 4" casing and is it under a windmill? It sounds just like my cousins.
    As Valveman says first you must repair the hole in the casing to prevent the sand coming in.
    Is this a one pipe (shallow well) or two pipe suction (deep well) setup? If it's a shallow well the well point may be plugged. If it's a deep well hookup it may have a well point on below the jet assembly and it may be plugged. In either case you are getting a limited amount of water to the pump.
Similar Threads: water pressure
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Yesterday at 7:40 AM
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure trouble shooting Nov 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Complete redo of water plant - replace pressure tank with CSV Oct 17, 2016
