Low water pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gdavidson, Dec 4, 2008.
  1. gdavidson
    gdavidson New Member
    Dec 4, 2008
    I have low water pressure in house, i have replaced tank:)
  2. gdavidson
    Dec 4, 2008
    I have low water pressure in my house. This just started recently. I have replaced pressure tank with no luck.
  4. jadnashua
    I assume you have your own well...you haven't given much info. Check the pressure gauge - what are the low and high settings for the pump? Is the pump running most of the time? Cycling on and off frequently in short cycles when no water is used or while you are running water?
    Lots of possible reasons, but you need to cough up more description of your system before anyone can help.
  5. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    When you got the new tank, did you scrap out the old Chinese gate valve? Those have a short life and the gate in them can break off and obstruct the flow.
Similar Threads: water pressure
Plumbing Forum, Professional & DIY Advice Fluctuation of water pressure Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Boiler shutting off... water pressure? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Low water pressure upstairs Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water Pressure Regulating Valve Question Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Disinfect new water pressure tank? Jan 8, 2017
