Low hot water pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Dan T1944, Nov 17, 2008.
  1. Dan T1944
    Dan T1944 New Member
    Nov 17, 2008
    Our house is 3 years old, PVC piping. Main supply water pressure is regulated at 50 psi. Pressure at hot water tank drain is 50 psi with all faucets closed, drops to 0-5 psi with any one hot faucet open. Is it a blockage at the tank inlet ???
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It could be.
    Is the valve on the cold supply to the water heater open all the way?
    What happens when you use cold water?
  4. Dan T1944
    Nov 17, 2008
    Inlet valve is open all the way. I also opened and closed it several times in case some trash was caught in the ball valve. Cold water is fine. Tank outlet is fine, since pressure drop is measured at the tank drain. I drained about 5 gallons from the tank, didn't help
Similar Threads: water pressure
Plumbing Forum, Professional & DIY Advice Fluctuation of water pressure Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Boiler shutting off... water pressure? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Low water pressure upstairs Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water Pressure Regulating Valve Question Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Disinfect new water pressure tank? Jan 8, 2017
