Low hot water flow all faucets
Snifferpro
Phoenix, AZ
A friend just called and said she has low hot water flow to all hot water taps.
She drained the tank by attaching a hose to the drain valve and shutting off the water coming into
The hose and opening the pressure relief valve.
She said there appeared to be no sediment in the draining water.
She then turned the water back on to the house, filled the tank, and had normal
Flow at hot water taps.
Later she called back and said flow was back to a trickle after the water had heated.
Any suggestions?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
More often than not, it is the reverse. Draining/refilling can cause a large sudden influx of disturbed sediment that can bung up the heat traps.
It has happened to me more than once and each time after I had turned off the all the water to work on the system. I am tempted to remove the heat traps entirely and probably will the next time I have to fight with it. The problem is my supply lines are hard copper and I'd have to cut and sweat in new fittings.
Snifferpro
Phoenix, AZ
After getting the old nipples out with considerable effort, I found that the ball in the cold water nipple was solidly attached to the side of the nipple and ball in the hot water nipple
was floating freely.
After replacing both, hot water flow is back to normal.
Again, thanks for the tip. saved a call to the plumber and I learned something new.
