Low hot water flow all faucets
Discussion in 'Water Heater Forum, Tanks' started by snifferpro, Mar 21, 2013.
  1. snifferpro
    snifferpro New Member
    May 15, 2011
    Phoenix, AZ
    A friend just called and said she has low hot water flow to all hot water taps.
    She drained the tank by attaching a hose to the drain valve and shutting off the water coming into
    The hose and opening the pressure relief valve.
    She said there appeared to be no sediment in the draining water.
    She then turned the water back on to the house, filled the tank, and had normal
    Flow at hot water taps.
    Later she called back and said flow was back to a trickle after the water had heated.
    Any suggestions?
    Thanks
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Heat traps can bung up causing that.
  4. snifferpro
    May 15, 2011
    Phoenix, AZ
    What is a heat trap
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  6. snifferpro
    May 15, 2011
    Phoenix, AZ
    Thanks, that did the trick
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    More often than not, it is the reverse. Draining/refilling can cause a large sudden influx of disturbed sediment that can bung up the heat traps.
    It has happened to me more than once and each time after I had turned off the all the water to work on the system. I am tempted to remove the heat traps entirely and probably will the next time I have to fight with it. The problem is my supply lines are hard copper and I'd have to cut and sweat in new fittings.
  8. snifferpro
    May 15, 2011
    Phoenix, AZ
    After getting the old nipples out with considerable effort, I found that the ball in the cold water nipple was solidly attached to the side of the nipple and ball in the hot water nipple
    was floating freely.
    After replacing both, hot water flow is back to normal.
    Again, thanks for the tip. saved a call to the plumber and I learned something new.
Similar Threads: water flow
Water Heater Forum, Tanks Moen cartridge, How do I turn off hot water flow to house? Jan 29, 2016
Water Heater Forum, Tanks "Superstore" 40 gal hot water tank discharging through overflow - why? Oct 25, 2010
Water Heater Forum, Tanks Therma-flow/Everhot water heater issues Nov 10, 2009
Water Heater Forum, Tanks New Water Heater Overflowing, Old One Didn't Apr 8, 2009
Water Heater Forum, Tanks Hot Water from Cold Tap Sunday at 7:28 PM
