rivergal
We had a new well dug for us 6 years ago after our old one caved in. The "new" 4" well is about 60' deep and has a submersible pump (one that is about 3 7/8" in diameter). As far as the quality of the water, it is hard, with hydrogen Sulfide and Iron. The H2S is more of an issue than the iron. We are a 2 person household, and used the water for garden irrigation when needed, and about 2 years ago had a water line leak that we found and fixed.
Last fall we started to notice the pressure dropping some, then later significantly -- going from 60 down to below 20 and staying there while any faucet was running. I takes several minutes for the pressure to rebuild.
We had the guy who put in the well come out, and he eliminated the easy stuff (pressure switch, tank, check valve, etc.) and said it was either a clogged well screen or problem with the pump itself. He said he could pull the pump and replace it for about 3k. He did say there was a potential, given the diameter of the pump, that we might not be able to get it out or it could break, and then a new well would be needed.
Since then we've been making do with the low flow, but know we will need to do something soon. My questions are:
1. Does this seem like a reasonable explanation for a 6 year old well?
2. How likely is it that the pump would stick?
3. Should we just go for a new well, rather than take a chance on this one?
3. Anything we can do in the meantime to help with pressure (another pressure tank?)
5. Any advice or experience in a situation like this would be appreciated!
