Low flow faucet problem with well system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by agmonaco, May 21, 2011.
  1. agmonaco
    agmonaco New Member
    May 20, 2011
    Aliquippa PA
    Can you increase flow on a well water system. they run at lower pressure than city water.. My well pump system ranges between around 30-40 PSI compared to city water at 60 plus PSI. These new faucets run at 2.2 Gallons per minute or less at 60PSI.. Lower pressure- lower volume..
    any ideas without destroying the faucet nozzle??
    Thanks Tony
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Depends on what you have for a pump system. A good pump can produce 60 PSI and coupled with a Cycle Stop Valve (CSV) can provide near constant pressure as well.
    The first question would be how/why the pressure switch is set to 30-40? Most switches have a differential of 20 PSI so 20-40 or 30-50 is more to be expected. Do you have a micronizer that may limit the range?
Similar Threads: flow faucet
Plumbing Forum, Professional & DIY Advice Low flow out of hot side of faucet. Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Reduced Water Flow in Single Bathtub Faucet Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Installing a new faucet, pressure seems too high going from Flowtite piping into new metal piping Mar 15, 2016
Plumbing Forum, Professional & DIY Advice Sink has no drain overflow, but faucet drain does Feb 1, 2016
Plumbing Forum, Professional & DIY Advice Low water flow in anti frost outdoor faucet Apr 19, 2015
