Loud hum from doorbell transformer
Discussion in 'Electrical Forum discussion & Blog' started by pit monster, Dec 29, 2009.
  1. pit monster
    pit monster New Member
    Dec 29, 2009
    Lancaster, PA
    I just bought an 1923 home which has a neat working door bell which may be original. Anyway there is a very loud buzz originating from the transformer.
    Could it be as simple as swapping out the transformer to eliminate the hum or is there any other trouble shooting I should do first?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    When a transformer gets old, the varnish and the rivets can get loose, and the plates will hum. It can also hum or get worse if it is overloaded. But the easiest thing is to replace the xfmr and see where you are. Try to find the output voltage and a volt/amp spec. number on it somewhere, and get one with the same output voltage, and at least the same minimum V/A
  4. jadnashua
    If it humms all the time, replace it if it bothers you. If it only humms while it is under load (i.e., the doorbell is being used), it could be too small. Best to look at the doorbell itself. They usually have a VA rating on the label. If your transformer is at least that large, it will work well.
Similar Threads: Loud doorbell
Electrical Forum discussion & Blog Loud boom and tripped breakers May 28, 2012
Electrical Forum discussion & Blog Exterior HID hums loudly when switch added Nov 21, 2009
Electrical Forum discussion & Blog Doorbell Wiring Dec 29, 2016
Electrical Forum discussion & Blog Where should doorbell transformers be mounted Nov 16, 2009
