Lost Hot Water Pressure Cause
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by Hujipher, Jul 6, 2013.
  1. Hujipher
    Hujipher New Member
    Reno, NV
    My master shower water pressure dropped suddenly. Coincidentally, it happened after my water softener ran out of salt and I replaced it (don't know if connected). 1st, cleaned shower head (looked like small whitish hard granules were plugging the inflow to the head). Didn't fix it much. Then, replaced the shower handle cartridge. Seemed to be all better for a day. Now, back to same weak pressure. Tub faucet in master bath (separate from shower) runs well but spits out some of the same whitish granular debris I found plugging the shower head (what is this stuff?). Rest of house seems unaffected. I've visually inspected the pipes in the crawl space and they all look fine. I'm absolutely stumped. Any help would be appreciated.
  2. Hujipher
    Hujipher New Member
    Reno, NV
    OK, new input. Isolated problem to the hot water supply line for that shower only. Copper. Acts like the supply line is partly obstructed. Spits out small whitish granules (? mineral deposits) that clog shower head. Do you think the inside of the hot water supply line for that shower is somehow corroded (mineral deposits) and showering pieces of debris through the shower, obstructing the head. How would it get corroded and how do you fix it? Thanks.
  3. jadnashua
    21,816
    Take the showerhead off, then turn the water on...that should purge the loose crap in the lines. Shutting the water off, then on again can dislodge all sorts of crud in the pipes.
  4. Smooky
    Smooky Member
    569
    NC
Similar Threads: Lost Water
Plumbing Forum, Professional & DIY Advice, Tips & Lost water pressure in my whole house after installation of a dishwasher?? Sep 21, 2011
Plumbing Forum, Professional & DIY Advice, Tips & Need help and info on low water presurre in house after replacing all lines,I am lost Jan 2, 2011
Plumbing Forum, Professional & DIY Advice, Tips & Lost water pressure Sep 18, 2008
Plumbing Forum, Professional & DIY Advice, Tips & During bath remodel I lost hot water. Help! Apr 28, 2006
Plumbing Forum, Professional & DIY Advice, Tips & Do I have a leak? Pressure lost on PEX Test Mar 6, 2014
