losing water
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by AWalker, Jan 5, 2009.
  1. AWalker
    AWalker New Member
    Jan 5, 2009
    We bought a house with a sand point well and I am learning on the fly. Recently we had to replace the pressure switch and we have and nothing but problems since then. After we replaced it, the pump would turn on every 20 minutes or so and run for about 10-15 seconds, we were told that we needed to replace the check vaulve. we replaced the check vaulve and fixed that problem. Since then any time the water does not run for a 3 or 4 hour period we lose our water completly. If we try to turn the water on we will get water for a little bit then it is gone completly, we are likly just getting what is left in the tank. When this happens we have to shut the water off to the house and let it rebuild pressure before we will have water again. Just wondering if anyone has any ideas on what my problems might be now.
    Thanks
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Sounds like possibly two problems. The leak that you say is fixed now, and a plugged pipe feeding the pressure switch. These pipes are small in size and can plug shut with minerals which shuts off the pressure switches ability to sense the actual pressure preventing your pump motor from starting.
    To get into it deeper, we need more info.
    bob...
  4. AWalker
    AWalker New Member
    Jan 5, 2009
    thanks I will make sure that there is no leak, and I will clean the pipe feeding to the pressure switch. If there is anything else that you can think of or any information that would help you assess my problem it would be appreciated.
    Thanks
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Check back after you take care of that, and let us know how it came out.
    bob...
Similar Threads: losing water
Pumps and Tanks Well Forum & Blog. Water is life. Xtrol Water Pressure Tank Slowly losing pressure throughout the day Aug 27, 2012
Pumps and Tanks Well Forum & Blog. Water is life. HELP! I keep losing water May 29, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Losing presure w/o any water being used in home May 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump losing water pressure with garden hose attached Jun 8, 2009
Pumps and Tanks Well Forum & Blog. Water is life. slowly losing water pressure Feb 17, 2009
