Losing Water Pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by klecas, Sep 28, 2007.
  1. klecas
    klecas New Member
    Sep 28, 2007
    We have a shallow well with a 1/2hp pump, a sand filter and water softner. Our problem started a couple of months ago and seems to be getting slowly worse. Our pump is set at 40/60 and cycles I think ok. The water pressure starts out ok when you turn on any faucet or shower but if you run the water open for more than a few minutes the water pressure drops alot. If trying to use a lawn sprinkler, it will work ok for a few minutes and then the pressure drops low enough that the sprinkler will not function. If using the washing machine it is now impossible to shower or even wash dishes because the water pressure will drop to a bit more than a slow stream. I don't know where to start, can you help me?
Similar Threads: Losing Water
Pumps and Tanks Well Forum & Blog. Water is life. Xtrol Water Pressure Tank Slowly losing pressure throughout the day Aug 27, 2012
Pumps and Tanks Well Forum & Blog. Water is life. HELP! I keep losing water May 29, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Losing presure w/o any water being used in home May 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump losing water pressure with garden hose attached Jun 8, 2009
Pumps and Tanks Well Forum & Blog. Water is life. slowly losing water pressure Feb 17, 2009
