Looking for air exchanger suggestions
bnymbill
Baltimore, Maryland
I’m in southern PA and while my insulated garage is great in the winter, it traps heat and humidity in the summer. In the evenings, the outside air is often cooler and less humid.
I am looking for an air exchanger (not sure if that’s even the correct term) that would pull outside air in and vent inside air out when the outside temp (or humidity) is cooler (less humid). I’m not sure if these units have settings for temp or humidity but either would likely work.
The thing is, it would have to sense both outside temp/humidity and inside temp/humidity because if it only senses inside, it would potentially be drawing in hotter, more humid air and work against the desired affect.
Would an ERV be the right product to accomplish what I’m looking for?
The garage is fully insulated and rocked and is 741 sq ft with 11’ ceilings to help with sizing.
WorthFlorida
Solutions
Orlando, Florida
Actually, night time the humidity is higher. It might seem less since the temperature drops. Get yourself a humidity meter to get a read on it. You can use any kind of exhaust fans, even a high volume squirrel cage bathroom exhaust fan. An ERV will not do anything for the humidity. Besides, what is there to recover? Exhausting heat with an exhaust fan, there is plenty of air leaks around the garage door to pull air on. Use a timer to turn on the exhaust starting at dusk for about four hours. If you go all night long you'll be pulling in humidity.
To go to the extreme, mini split AC units are very low cost and some are made for the DIY'er. If you get one with a heat pump, you can use it in the winter for a little heat if needed.
I don't think so. I think ERVs are for when you want to keep the inside (heat/cool) and/or (humidity/dryness), but to get new air.
A fan would be more what you want to bring in the outdoor temperature and dryness.
In turning on a fan for tumidity control, I think the dew point is a better number to watch than relative humidity.
https://en.wikipedia.org/wiki/Energy_recovery_ventilation
Dana
In the trades
That's not exactly true. The relative humidity of that cooler outdoor air is lower, but the absolute humidity of the outdoor air usually (but not always) falls a bit at night as the radiational cooling into the night sky brings objects down to the outdoor dew point, causing moisture in the air to condense out onto leaves/grass/roofs, etc. When there is solid cloud coverage there is very little radiational cooling, and very little change in the absolute outdoor humidity levels as measured by wet bulb temp or dew point. When the sky is clear radiational cooling can bring surface temps to well below the ambient air temps, but it can't drop below the dew point temp of the proximate air.
To control a ventilation fan as a dehumidifier the controls need to track & compare the DEW POINT temperatures of both the outdoors and indoors to know whether night ventilation would provide any dehumidification.
An ERV does not dehumidify any more than a dumb ventilation fan does. But it will somewhat equalize the absolute humidity between the incoming and outgoing air streams.
A right-sized mini-split will definitely dehumidify & cool the space. But oversized mini-splits have a lousy sensible heat ratio, since the compressor only needs to runs at it's minimum modulated levels with a warmer coil to keep up with the sensible heat load, leaving the space clammy-cool rather than dry-cool. A lot of DIYers will drop a 2 ton mini-split in to a garage or shop space thinking "bigger is better", and that allows them to cool the place off quickly, but it doesn't dehumidify adequately, and it doesn't operate as efficiency cycling on/off rather than modulating with load.
That said, most mini-splits come with a "DRY" or "DEHUMIDIFY" mode, which keeps the coil appropriately cool for maximum dehumidification. Most mini-splits do NOT control to either a humidity or temperature when operating in that mode, but some do. Fujitsu mini-splits will control to the temperature setpoint even in DRY mode, and Daikin's Quaternity series has independently settable temperature and relative humidity setpoints. Most of the DIY mini-splits are re-labeled Midea units, all of which have a DRY mode that just keeps chugging away no matter how cold it gets indoors.
If the garage has double-hung or single hung window, Midea has a series of pretty-good modulating window-shaker AC units that have a DRY mode, ( and a pretty big turn down ratio too.) It's essentially a "cooling only mini-split in a can". (The hand held remote is identical to the remotes shipped with most Carrier and Midea mini-splits, and even has a "HEAT" mode indicated on the remote, but the unit itself is cooling-only.) I recently installed the 1-ton version in my open-loft home office that is under-served by the (ludicrously oversized) central AC. The office looks out over the kitchen and has an open stairwell to the living room. With the Midea set to 74F and the central air set to 76F the window unit carries the bulk of cooling load, and except during the most torrid days keeps the indoors to under 55% RH @ 74-76F. When the outdoor dew points are in the 70s switching it to DRY mode for several hours still holds the line on humidity, even if the central air never cycles. But if left in DRY mode overnight it'll be pretty cold in the kitchen in the AM. Depending on how much window area, how air leaky, insulated, & large the garage is the 1-tonner is probably enough (and not too much) for controlling both heat & humidity. A 500-600' garage. (It keeps up with my 2400' house until the low to mid 90sF outside.) It's pretty quiet too- not as quiet as a better-class mini split, but by far the quietest window unit out there, and cheaper than a 3/4 ton DIY minisplit. (Rated at CEER 15 it's substantially more efficient than my old 10 SEER central air too.) There were availability issues and some price gouging going on early in the summer, but those seem to be easing. I only got the 1-tonner because at the time the street price of 8000 BTU units were higher than the 1-ton (1), and hard to find (at any price.)
Fitter30
Peace valley missouri
Dew point sensors are not cheap plus have to be connected to a processor and power supply plus programming. Its a garage didn't ask for heat just some lower RH. Have no idea how big the space is or the budget.
bnymbill
Baltimore, Maryland
Thank you for all of the suggestions and input! Definitely a lot to consider. I have a sensor in the garage and one outside as well to track temp, humidity and dew point. Ended up with a fan that can be set for temp, humidity, or timer to experiment with the settings. Affordable enough at $200 with odds and ends for installation.
I ended up buying this fan:
https://www.amazon.com/dp/B07QXDM2P8?psc=1&smid=A2S5G2QI5MZGC&ref_=chk_typ_imgToDp
Also bought a vent cover for the exterior to beef up the installation:
https://www.amazon.com/gp/aw/d/B07MG15G4R?ref=ppx_pt2_mob_b_prod_image
