Looking for a low cost propane room heater
Mikebarone
DIY Senior Member
Phoenix, AZ
Hi…I’m trying to find a low cost venting, (from the outside) propane heater. It is for a small apartment, (approx 250 square feet). All of the ones I have found on the web, are around the $600.00 to $700.00 range and up. I don’t really feel comfortable with the heaters that (use the air from inside of the room) monitor the oxygen in the air, because there will be people that sleep in the apartment, (for the danger of CO poisoning). I can’t use electric heat, because the main breaker is so small…older building, and everything runs off of gas.
Any suggestions?
Mike
heater
You CANNOT use an open flame burner in any sleeping area. The external intake/exhaust units ARE expensive, because they are more than just a burner.
Mikebarone
DIY Senior Member
Phoenix, AZ
Thanks,
Thanks HJ,
This heater will be for a client/friend of mine that has some small hotel type rental houses in Wilcox Az. She found one of those, “Mr. Heater portable propane heaters†on the web, and that’s what she wanted to use. I told her the same thing, about not being able to use that type of heater in those houses.
I did find her some bolt on to the wall type heaters one the web that have the heat exchanger so no flame is in the house, but I was hoping that someone might know where she could get one a little cheaper then the ones I found.
Thanks again,
Mike
Cass
For 250 Sq. Ft. why not go with an electric heater?
Mikebarone
DIY Senior Member
Phoenix, AZ
Elec heat no good.
From what she’s told me, these little rental units were built like in the 40’s, and the power supply to the main panels is almost noting. She says that with just one small electric heater on low, and the TV and some lights on it blows the main breaker. Everything there runs off of gas…stove, HWT, dryer etc. She said she looked into getting the electric company to come out and give her a bigger service, but it would cost her a lot to up grade her side of it.
I know, it seems a little strange to me too that the electric panel out there wouldn’t handle such a small load. I should tell her that I’d go out there and check out the electrical system, but damn that’s a long drive….LOL.
Mike
