Life expectancy of a bladder tank
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Bob999, Sep 25, 2009.
  1. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    What is the life expectancy of a bladder tank and what are the typical causes of failure? Is there is significant difference in life expectance between steel and composite tanks?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    seen some better than 20 years old and still going, seen some go in 2 years.
  4. Gary Slusser
    Retired
    I've seen Gould's and Well-X-Trol last 20-25 yrs. The primary cause of failure is incorrect air pressure.
    Composite/plastic will usually last much longer but their bladder (bag) is not as 'robust' IMO.
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
  6. Stacystark
    Stacystark New Member
    Sep 27, 2009
    Carlisle, KY
    I can only say that mine, which was installed in 1978 still works. It had a problem last year where water got outside the bladder in the tank, but my plumber was able to drain and fix it. He did say it may have damaged the pump.
    Seems he might be right, as now the pump is sounding a bit different when it kicks on. The pump, a 1/2 HP,was installed with the tank, also in 1978, so it's lasted a long time.
    Which is why I joined this Group. I am looking to educate myself on the mechanics of (relatively)shallow, non-submersible pump motors.
    Stacystark
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    How deep is your well. . .?
Similar Threads: Life expectancy
Pumps and Tanks Well Forum & Blog. Water is life. Life expectancy of galvanized pressure tank? Aug 14, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Simmons "lifetime warranty" check valves & Products Sep 2, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Cycle Stop Valves: Can They Shorten The Life Of Your Well Pump? Apr 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well hole plumbness and pump life. Apr 29, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Life Oct 20, 2014
