Leaking tub faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by trobinson017, Oct 28, 2004.
  1. trobinson017
    trobinson017 New Member
    Oct 28, 2004
    Hello,
    I have a 20+ yr old Gerber 3 handle tub faucet setup; hot and cold knobs and a diverter knob in the middle. The hot/cold stems were leaking so I replaced everything; both stems with new valve seats,washers, etc. and a new diverter with a new seat/washer. The stems no longer leak but now I have water dripping from the tub faucet. I crank down on the hot/cold knobs but it still drips, although slower. I took everything apart and checked all the flat washers and the tightness of the seats. All were as they should be. I even went ahead and replaced all the flat washers. I put it all back together and the faucet still drips.
    What more can I do? Any ideas??
    Tim
  2. Bob's HandyGuy
    Bob's HandyGuy Senior Member
    Sep 10, 2004
    Does it drip only after you use the shower? There is a column of water in the shower pipe when you shut the water off. If so, then water is getting past the diverter. Open the diverter after the water is shut off and let it drain. If it still leaks, check the temperature of the water after awhile. This will help you isolate which valve might need re-doing.
Similar Threads: Leaking faucet
Shower & Bathtub Forum & Blog Shower head leaking when tub faucet is on Jun 2, 2016
Shower & Bathtub Forum & Blog Tub faucet leaking every 10 seconds Jan 18, 2016
Shower & Bathtub Forum & Blog Help trying to replace leaking O-ring in Moen Traditional kitchen faucet Dec 13, 2015
Shower & Bathtub Forum & Blog Water leaking from back of dome nut (Delta single tub faucet) Apr 19, 2015
Shower & Bathtub Forum & Blog Leaking Moen Roman tub faucet - can't ID brand - HELP! Feb 22, 2015
