Leaking shower
Discussion in 'Shower & Bathtub Forum & Blog' started by horseman, Nov 29, 2005.
  1. horseman
    horseman New Member
    Nov 29, 2005
    Please someone could you please advise, we have never experienced this before. We just bought a house and moved in 2 days ago. For the last 2 days the shower in the master bath leaks through the bottom of the brick wall and out onto the patio. This bathroom was just remodeled with tile on ceiling and walls. I hate to tear it out. It is in the back of the house and the water valves are on the inside of the outside wall. I noticed yesterday and today after the shower had been run that water was seeping out through the bottom of the brick wall down the foundation and out on the patio. There was also foundation work done on that end of the house before we closed and I wonder if that could have done something to the plumbing under teh shower. We just don't know where to begin. The house is 20 years old, but like I said bathroom shower was just remodeled before we moved in.
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Is this a shower only or a tub/shower?
    Does it leak constantly (as in a water line leak) or just when the shower is in use (as in a possible above-the-faucet or drain leak)?
    What type of faucet does it have? Brand? Single handle? Dual handle?
    Please give us a little more detail. There are a few things that you can try, if it isn't a constant leak, without tearing into the wall.
    Mike
  4. horseman
    horseman New Member
    Nov 29, 2005
    leaky shower
    Thanks for your fast reply. I am not sure of the brand, I will check tonight. There are two handles for the water. It only leaks through the bottom of the wall whenever the shower is running. It is only a shower it is custom built. There may have been a combo there before by looking at the size of the shower, but the remodeling only has a shower with ceramic all over the place. Also, we switched to other bathroom today to use it instead. There is a shower/tub combo. Well things worked there until about 3-4 minutes into the shower, then we lost hot water. My wife took a shower after me and she had the same problem. Plenty of hot water just not after 3 -4 minutes. Could the previous owner have put some device in to cut the showers short or is there a bigger problem here too?
  5. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Sounds like you have multiple issues. Might be time to call in a pro. Not to be disrespecful but this cold / no shower thing is going to get old FAST !
    Cal
  6. Mike Swearingen
    Jan 12, 2005
    Also sounds like you may have a problem with a bad element or tstat with your water heater.
    Mike
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    shower
    Just at first glance it sounds like the shower pan leaks.
    Could also be leaking at the faucets packing or through the wall when showering.
    With the hot water it sounds like the dip tube has split or broken off....
    Its on the cold water nipple on the heater tank or just inside where the nipple screws into the water heater..
  8. jimbo
    jimbo Plumber
    A quick check for the shower: remove the shower head, and cap the arm with a plastic 1/2" IPS threaded cap. Then turn the water on for a few minutes, see if the leak occurs. This will tell you if the leak involves the water piping and valves, or the shower pan and drain.
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    shower
    Check the pan by putting a stopper in the shower drain and go to a different fixture and bring in 2 or 3 pails of hot water and dump them on the shower floor and wait......
    If it leaks at the wall then you know its the drain line or the the pan. and then there may not be a pan at all.
Similar Threads: Leaking shower
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Remodel shower stall kits prone to leaking? Nov 8, 2016
Shower & Bathtub Forum & Blog New home - leaking shower arm inside wall Oct 26, 2016
Shower & Bathtub Forum & Blog Shower drain leaking Aug 13, 2016
Shower & Bathtub Forum & Blog Leaking shower drain: help replacing from top Jul 1, 2016
