Leak in PVC soil pipe under slab
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ardose, Nov 18, 2004.
  1. Ardose
    Ardose New Member
    Nov 18, 2004
    Of all the rotten luck! My PVC drain system passed the rough-in pressure test. The slab was poured and I installed the above slab rough-in drain system. It failed pressures testing. After spending hours and days testing, I found exactly where the leak is.
    It is a small, pin hole size leak in a 3 inch PVC soil pipe joint under the slab. I can get to it with a wire from inside the stack pipe but, it appears that I will have to break through the slab to get to the outside of the joint.
    Is there any other way to fix the leak without breaking the slab?
  2. hj
    keak
    Not likely. What caused the pin hole? If it was shattered then there may be other damage you cannot see.
Similar Threads: Leak soil
Plumbing Forum, Professional & DIY Advice Vent Pipe/Soil Stack Leak Feb 2, 2009
Plumbing Forum, Professional & DIY Advice Leak in Cast Soil Stack Mar 28, 2008
Plumbing Forum, Professional & DIY Advice Leaking Soil Pipe Dec 27, 2006
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
