Leak at check valve on my well.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by JasonH, May 12, 2013.
  1. JasonH
    JasonH New Member
    May 12, 2013
    Florida
    I have a leak at the fitting on my check valve by my well. Should I replace the entire check valve, or is it possible to repair this another way?
    Here you can see the leak when it's pumping:
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    To repair the leak will require removing the check valve. At that point I would replace the check valve along with the two males.
    John
Similar Threads: Leak check
Pumps and Tanks Well Forum & Blog. Water is life. Where would the leak happen related to the check valve? Mar 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Leaking check valve? May 1, 2006
Pumps and Tanks Well Forum & Blog. Water is life. Winter well leak Dec 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 leaking Nov 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well, Leak at Pitless Adapter Oct 5, 2016
