leads insert, what to do?
Discussion in 'Toilet Forum discussions' started by steveg91, Apr 7, 2010.
  1. steveg91
    steveg91 New Member
    Aug 14, 2006
    Hi folks, the picture says it all. How do I put this back together?
    1. Is there a closet flange that will seal into the lead insert?
    2. Is it accetable to put it back like it is with a new fernco seal, I don't like the lag bolt screwed into the subfloor system.
    3. Or how else should i put it back together?
    It was not leaking, the vinyl is being replaced, thats the reason the toilet was pulled.
    Thanks so much
  2. hj
    How WE would do it may not be the easiest way for you to do it, and you could create major problems if done wrong. We would straighten out the lead, put a brass flange over it and anchor it to the floor, roll the lead back down, and then solder the lead to the brass flange.
Similar Threads: leads insert
Toilet Forum discussions Broken Cast Iron Flange too Deep for insert replacement Sep 28, 2011
Toilet Forum discussions Fluidmaster Pro 45B white insert? Jan 15, 2010
Toilet Forum discussions Toilet flange did not insert- HELP! Feb 18, 2009
Toilet Forum discussions Has anyone had experience with TwoFlush or similar inserts Jul 28, 2008
Toilet Forum discussions using flange insert for repair Jan 23, 2005
