Hi,
I am installing a utility sink in the laundry room. I currently have a fairly standard setup (see attached photo). Since the sink is fairly deep, I will have to lower the drain opening so that it is only a few inches above the inlet to the P trap. I plan to place the washer outlet hose on the rim of the sink so that it empties into the sink. My question has to do with whether there will be sufficient pressure for the water to flow through the P trap without backing up (P trap is partially hidden in photo by drywall). Do building codes specify a minimum vertical distance between the P trap inlet and outlet? Also, prior to doing the sink installation, I need to temporarily hang the washer outlet to the drain so that it is just a few inches above the P trap inlet (so we can use the washer). And again, my concern is that it will back-up.
Thanks,
Carlos
Thanks,
Carlos
