Laundry closet challenge
diyguy4
Valparaiso, IN
Laundry closet venting challenge
Hello Experts,
I live in a 1500 sq. ft. ranch on a 4' crawl space with full access under the walls. I am trying to rework the plumbing in my 36" deep closet so that we can have enough depth for a front load washer and dryer. I need to install a recessed valve & drain box properly, but I have a toilet vent in the same stud cavity as the washer vent pipe. (Please see the attached photos.) Can I share the toilet vent stack with the washer drain vent? This may give me just enough room to get the trap in the wall. If so, how do I close off the original washer drain and retain the venting to the roof? If not, how can I plumb this closet so that we can stop going to the laundrymat?
Dimensions: Top of original washer drain stand pipe: 34" AFF. Existing washer valves are at 45 1/2" AFF. Distance from right wall (face of drywall) to center of toilet vent is 21-1/2". Distance from right wall to center of washer vent is 14 1/4".
Please help !
DO NOT drain the washer into the toilet vent. It can, and often does, create a venturi effect as it flows past the toilet connection sucking the water out of the toilet. You can offset the toilet vent to the left and then install your drain box after you raise the washer drain tee so the trap is above the point where you have offset the other vent. You might be better off installing the washer drain into the lavatory drain if that is the pipe next to the dryer vent. It might work out better since most front load washers have the hinge on the left side, from the factory, so the washer works better on the left side of the dryer, unless you wish to reverse the doors on both appliances. (Doing that will result in any writing on the door being upside down, however.)
