lake water supply setup. in Ct lake
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by tooks007, Oct 3, 2011.
  1. tooks007
    tooks007 New Member
    Mar 22, 2011
    north stonnington,ct
    Hi i have been handed down a nice cottage in north stonnington, Ct and i am trying to get a proper setup for the water supply.The lake is long pond, and the water line has been buried quiet a few feet underground and it has heat line installed previously..the pump and pressure tank where taken from under the cottage where i assume they where.I need to know what size pump,pressure tank,and if they should be under the cottage.there is a nice setup for the cistren tank and i guess the pump and etc where there.please any help with the proper water supply setup for this lake would be greatly appreciated.
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    We would need much more information before we can make a proper determination. Is there a check valve on the line in the lake? What's the elevation from the lake level to the cottage pump area? What's the water to be used for. . . drinking, house use or irrigation? How many bed and bath rooms?
  4. tooks007
    tooks007 New Member
    Mar 22, 2011
    Hi thanks for your reply,yes there is a check valve on the lake end of the water line, and there is one bathroom small kitchen and dinning,and fireplace room.The water will only be used to bath in and wash dishes outside use as well.the elevation im not to sure of back yard walks down in a slight slope not to slanted sorry for the lack of elevation .my farther has a bigger cottage across the street that has alot higher elevation and i know he uses a 1/2 hp pump,pressure tank,check valve online in lake,hot water heater and he gets good pressure.
  5. masterpumpman
    Mar 26, 2007
    Virginia Beach, VA
    To keep it simple, I'd set it up simular to your fathers! A 1/2 or 3/4 hp shallow well jet pump and a small 5 gallon pressure tank should be enough. Be sure to install a tank and possibly a Cycle Stop Valve.
  6. tooks007
    tooks007 New Member
    Mar 22, 2011
    thanks alot for your reponse but i have a question for you. In combination with the pump,5 gallon pressure tank,check valve,hot water heater,filtration for water, what is the( tank and possibly a Cycle Stop Valve) for? And what kind of tank are you referring to. Again thank you for your help it has been very beneficial to me.
  7. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    A 5 gallon tank provides just over a gallon of drawdown. The CSV is almost a must with so small a tank. It provides constant pressure and prevents the pump from short cycling.
  8. tooks007
    tooks007 New Member
    Mar 22, 2011
    Been a while but need to ask another question my cottage will supply water for 3 to 4 people and i want to make sure that i can have enough water pressure and hot water to give bathing water and kitchen water to use daily. and possibly can u help with a filtration setup ? my parents have used this lake water to bath with and use a basic filter inline setup from lowes and have never had skin problems or gotten sick but the water has a slight smell and can have a little dirt color , very light though.
  9. masterpumpman
    Mar 26, 2007
    Virginia Beach, VA
    If the pump supplies enough water you should be OK with a small tank if you install a CSV. Install a filtration setup if you like but be sure it's installed after the pressure switch. If not a plugged filter can damage your pump.
  10. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Before you pump anything from the lake you need to check in with the local and possibly the state plumbing board and find out if using lake water is allowed. Code says that water supplied to fixtures has to be potable. In other words, fit for human consumption (no bugs and bacteria's) Very often the level of coli-form bacteria is way beyond what is considered safe. Usually due to ducks and geese crapping in the water but there are other harmful blooms that occur as well.
  11. tooks007
    tooks007 New Member
    Mar 22, 2011
    Hi how are you again i have another question here I'm looking for a good filtration setup to add on after the pressure switch ? new to this whole water setup
  12. ballvalve
    Dec 28, 2009
    northfork, california
    I would do a series of whole house filters with decreasing microns, then a UV light for bacteria. For a part time cabin on a little jet pump, its quite a stretch to reccommend a cycle stop valve.
    Go see the neighbors and see what they do.
Similar Threads: lake water
Pumps and Tanks Well Forum & Blog. Water is life. May I leave my lake water pressure tank out over winter? Oct 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Keep water line from lake from freezing/ Sep 7, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Problems pumping lake water to cottage Aug 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. lake water pump/tank prssure bounce question Jun 5, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Lake water pump cracked housing - trying to determine best option with changed needs Apr 29, 2014
