Kohler Tea for Two Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by DSanduril, Sep 9, 2009.
  1. DSanduril
    DSanduril New Member
    Apr 7, 2009
    We're considering a drop-in installation of a Kohler Tea for Two soaker tub. My distributor has given me a couple of horror stories about the "required" Kohler drain, and I've seen more online. Plus, the only drain they have is a brass slip joint, and I'd prefer to go with a glue up to avoid the access panel (it would have to be in a very inconvenient and unattractive place).
    Has anyone here installed the Tea for Two with a drain other than Kohler's? I'd probably have to give up on the matching square overflow plate, but I'm willing to do that if I can get a good drain in. I'd probably prefer to go with a simple twist-and-turn or maybe a toe tap, but any recommendations most welcome.
    Thanks.
  2. hj
    drain
    "Jillions" of slip joint drains have been installed without access openings. Once they are installed properly, there is no reason to get to them, no more than with a glued drain. The tub openings are standard so you can use any drain you wish to with the tub.
Similar Threads: Kohler Drain
Shower & Bathtub Forum & Blog Which Kohler Archer drain do you prefer? Jan 16, 2017
Shower & Bathtub Forum & Blog Drain shoe gasket will not seal on new Kohler acrylic tub Jun 8, 2014
Shower & Bathtub Forum & Blog Kohler tub drain assembly Aug 16, 2013
Shower & Bathtub Forum & Blog Question about finish on kohler castiron tub drain pic attached May 1, 2013
Shower & Bathtub Forum & Blog Kohler Villager being used in a basement bath remodel, drain and trap in concrete Mar 27, 2013
