Kohler Rialto flush gasket issue
Discussion in 'Toilet Forum discussions' started by bhinda8, Aug 26, 2011.
  1. bhinda8
    bhinda8 New Member
    Aug 26, 2011
    Plano, TX
    I'm trying to replace the flush valve gasket in a Kohler Rialto toilet. I was able to get the old gasket off relatively easy.But I'm having a hard time turning the plastic piece (not sure what to call it-flapper assembly/flush valve?) with the new gasket.I can't get any leverage and I don't want to break it using channel lock pliers.It only needs about an eighth turn but I'm not getting anywhere.Any tips would be appreciated.
  2. jadnashua
    Push it down while trying to turn it and see if that helps.
  4. bhinda8
    bhinda8 New Member
    Aug 26, 2011
    Plano, TX
    Thanks for your response.That was a suggestion Kohler support provided and I had tried that without success.I just couldn't get a good enough grip to turn it.I did find a solution however.I applied a pure silicon lubricant to the gasket side that that touches the porcelain, the three plastic teeth and the part of the flange that the teeth slide over.I was able to turn it relatively easy.
Similar Threads: Kohler Rialto
Toilet Forum discussions Need to replace an old Kohler Rialto Jan 5, 2016
Toilet Forum discussions Kohler 3402 Rialto toilet ? Replace parts or use conversion kit? Oct 12, 2015
Toilet Forum discussions Kohler Rialto K-3402 Footprint diagram Mar 29, 2015
Toilet Forum discussions Kohler Rialto(?) flapper valve replacement Sep 25, 2014
Toilet Forum discussions Kohler Rialto toilet 1984 Nov 23, 2013
