Kohler Pedestal Sink Install
Discussion in 'Remodel Forum & Blog' started by mekump, Aug 31, 2006.
  1. mekump
    mekump New Member
    Mar 24, 2006
    Computer Eng
    Maryland
    Hello and thank you for your help
    I am installing a Kohler Portrait pedestal sink and the back of the sink that mates up to the wall is very uneven. If I level the sink I have about a 1/4" inch gap between the wall and the top back of the sink. Should I level the sink or should I mount the sink so that it is flush to the wall?
    Mike
  2. Zach
    Zach New Member
    Jan 9, 2005
    The sink shouldn't need to be level front to back. You can probably install it flush to the wall, shim the base to support it properly, and then grout or caulk around the base to hide the gap and shims.
  4. jadnashua
    If you wall is flat and level, and the sink is the wavy part...take it back as it is defective. The thing cost enough, they owe you a good one.
  5. mekump
    mekump New Member
    Mar 24, 2006
    Computer Eng
    Maryland
  6. Oyama
    Oyama New Member
    Nov 9, 2006
    I also purchased Kohler Memoirs pedestal sink in 2005 and only had a chance to install now. I immediately noticed on mine that the back of the sink was uneven too and to make matters worse so was my wall slightly. Now I have a 1/4 inch gap to deal with.
    Since I cannot take it back now, should I just place a couple of shims along the back side and caulk over it? I just want to make sure that the sink is properly secured having two children in the house.
    After reading all the complaints that others have had with their Kohler sinks and toilets, I will no longer be buying a product from them again.
  7. Howard Emerson
    Howard Emerson I teach guitar:You call that a job?
    Apr 28, 2008
    Huntington Station, NY
    To both of you with the warped-back pedestals,
    If for some reason you have not yet tiled the wall where the sink is butting up to, I would 'scoop' out the sheet rock so that that top edge made contact, and then tile from there.
    Porcelain of any brand is hardly ever perfectly formed. It really tends to slump somehow, someway, in one direction or another.
    HE
  8. Oyama
    Oyama New Member
    Nov 9, 2006
    Howard, thanks for your reply.
    Unfortunately, I've already tiled my walls. This issue with porcelain is new to me but I would expect much better quality control coming from Kohler (they sure charge enough).
    Here's a photo of my sink:
    [​IMG]
  9. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    caulk it
    you are simply going to have to caluk it with some dap
    their isnt much you can do about it now except learn to live
    with the large bead of white caluk along the back...
  10. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    I've found Kohler products to be terrible.
    Tom
  11. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Pedestal sink install
    Coming from a professional what i always do in this case is get plumbers putty, roll into a string and push down into the crack filling as much as possible, then use dap caulking to seal with
    TRYING TO USE DAP OR ANY CAULKING ALONE WILL JUST RUN DOWN THE WALL
    use a small wet sponge to smooth out the caulking keep rinsing out sponge in sink till you get a smooth bead across it
    then do not ! ! Use sink for 24 hrs. Till caulking cures
  12. hj
    sink
    quote; If for some reason you have not yet tiled the wall where the sink is butting up to, I would 'scoop' out the sheet rock so that that top edge made contact, and then tile from there.
    I hope you are not telling him to mount the sink and then tile down to it. If so, then there is no need to "scoop" the sheetrock because the tile will cover the gap anyway. But it will also make the sink impossible to remove later if they use the hanger brackets that come with some sinks.
  13. Howard Emerson
    Apr 28, 2008
    HJ,
    The only pedestal sink I ever installed was fastened with bolts and washers through holes from underneath, but I understand what you're talking about.
    It was too late in any case.
    HE
Similar Threads: Kohler Pedestal
Remodel Forum & Blog Installing Kohler K-1160G Air Bubble tub Feb 14, 2016
Remodel Forum & Blog What whites best match Kohler white? Sep 24, 2011
Remodel Forum & Blog Kohler Design Video Jun 26, 2010
Remodel Forum & Blog kohler flow restrictors? Apr 17, 2009
Remodel Forum & Blog Kohler Faucet Jan 26, 2006
