Kitchen Faucet Located Close to Wall/Backsplash
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by moeronn, Oct 29, 2009.
  1. moeronn
    moeronn New Member
    Feb 4, 2008
    California
    I wasn't sure if this should go here or in the remodel forum, but since it is an existing condition I'll start here.
    I'm looking at a house where the kitchen faucet is installed very close to the backsplash/wall. It is so close that the handles and the base are nearly flush against the wall.
    The faucet is similar in style to this one.
    [​IMG]
    Are there any potential issues with this other than it might be difficult to replace (or turn on and off. ;) )?
  2. hj
    faucet
    As long as it has lever handles, AND is a ceramic seat faucet with 1/4 turn operation, there should be no problems. IF it is not ceramic, but uses rubber washers, you WILL have a problem when they start to wear and the handles start shutting off closer and closer to the backsplash.
  4. moeronn
    moeronn New Member
    Feb 4, 2008
    California
    Thanks for the reply. The faucet does have quarter turn handles, but I'm not sure if the washers are ceramic or rubber and probably wouldn't find out until something starts leaking. The main downside is that options for replacement will be fairly limited because of the tight fit.
  5. hj
    faucet
    With a quarter turn faucet it makes no difference because the handle will never rotate any further backwards than it does now.
Similar Threads: Kitchen Faucet
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet ID Jan 26, 2017
