Kinetico water softener problems
rjoubert
McCordsville, IN
I have a 4-tank Kinetico water softener (the model number listed on the original invoice is M4040). It has recently stopped regenerating. I have tried to manually regenerate it, but it didn't do anything. Also, I noticed some water around the tanks on the floor. The system was installed about 6 years ago. Any suggestions on what I can check before calling a service technician? Thanks...
Chevy427
USA
So when you try regen it, it just sits there and won't go thru its cycle? If that is the case, the regen pawl is broken or out of alignment. Have you taken the valve apart at all?
rjoubert
McCordsville, IN
Of course, after I submitted my post, what should I hear? The system finally regenerated by itself. I wonder if I could have done something by attempting to regenerate it manually? All I did was turn that phillips screw clockwise a couple of times.
