Kinetico softener not working.
Discussion in 'Water Softener Forum, Questions and Answers' started by thrice910, Jun 16, 2010.
  1. thrice910
    thrice910 New Member
    Jun 16, 2010
    Chicago
    Hello, I have a Kinetico Mach series water softener and I don't think it it is working. I moved into my home about 4 months ago and the salt is at the same level as when I moved in. The unit does regenerate but I think there is a problem with the Brine valve/float.
    I opened up the brine tank and removed the brine valve/float and I noticed that the float did not freely open or close the valve.(unless I forced it up the post). I am assuming this should freely open/close based on the actual water level.
    Any input would be greatly appreciated. :)
    [​IMG]
    [​IMG]
    [​IMG]
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    Take it apart, clean it off and re-assemble. There are probably O rings in there that may need replacing
  4. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    If it is not regenering on it's own, the meter may not be working, the unit may be on bypass, the regen drive gearing is not turning or it's hooked up wrong (least likely). You can turn on your water and watch the meter drive pawl to see if it moves. Placing a phillips screwdriver in the center and turning clockwise will start a cycle. Once started, see if it will finish on it's own.
  5. thrice910
    Jun 16, 2010
    Chicago
    It is regenerating, I took it apart and everything looks OK. I think it is working now.? Time will tell, Thanks!
Similar Threads: Kinetico softener
Water Softener Forum, Questions and Answers Kinetico Mach Quad Tank Softener Jan 22, 2017
Water Softener Forum, Questions and Answers Kinetico Softener with salty taste during regen. Help!!! Aug 21, 2015
Water Softener Forum, Questions and Answers Kinetico water softener and salty tasting water Aug 10, 2014
Water Softener Forum, Questions and Answers Question about Kinetico softener 60 Feb 26, 2014
Water Softener Forum, Questions and Answers Kinetico water softener problems Jul 27, 2013
