Help with understanding KINETICO 60 SERIES BRINE TANK FLOAT HEIGHT ADJUSTMENT
CJCastiglione
NW Pa
I have a 60 SERIES KINETICO and I'm looking for info on how to properly adjust the BRINE VALVE FLOAT HEIGHT. I'd also like to understand the science of how it works. Thanks in advance.
I am not going to give you a tested procedure, but the float setting determines how much salt gets used for each regen.
I could come up with an estimate of how far above the where brine level bottoms out at (during brine draw), and where the float should cut off flow. For that, I would want media tank dimensions and diameter of your round brine tank. I am not a pro, and I have never seen a Kinetico .
