Kinetico Model 60 won't draw
Discussion in 'Water Softener Forum, problems, installation and r' started by GaryG, Sep 3, 2012.
  1. GaryG
    GaryG New Member
    Sep 3, 2012
    Washington
    Hi,
    I have a Kinetico Model 60, which stopped drawing brine. During the brine cycle, water continues to flow to the brine tank (no suction). It won't drwa on either the normal timer or the manual regeneration.
    Here is what I have done already:
    1. disconnected brine line (confirmed there is no suction, but rather water flow from the head)
    2. blew out drain line (it was not plugged)
    3. Took Head apart
    .... confirmed gears and turbine spin freely
    .... blew air through the venturi and all the openings
    .... verified all the valves move freely
    .... confirmed check valves are in place.
    Any ideas on what to try next?
  2. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    In the base level, are there balls or pegs? The brine draw occurs about two minutes after regeneration initiates.
    Water pushes toward the brine tank during all other stages.
    It could be the control disc is worn. Have you checked the ridges?
  4. GaryG
    GaryG New Member
    Sep 3, 2012
    Washington
    The base level has pegs. The unit is almost new. The control disc doesn't look worn.
    Gary
  5. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Check the drain flow controller for the debris. Hold the venturi up to the light to make sure no blockage is present.
  6. GaryG
    GaryG New Member
    Sep 3, 2012
    Washington
    Hi,
    Checked the drain flow controller and it was clear. Also checked the venturi, which was also clear.
    Any other ideas?
    Thanks
    Gary
Similar Threads: Kinetico Model
Water Softener Forum, problems, installation and r Kinetico Model 30 won't stop draining... Jan 10, 2016
Water Softener Forum, problems, installation and r Kinetico - Model 51 - Will not draw brine Jun 11, 2015
Water Softener Forum, problems, installation and r Kinetico Model 60, 1 tank now very loud during brine rinse Mar 10, 2015
Water Softener Forum, problems, installation and r KINETICO Model 60 PAWL LAYOUT Sep 15, 2014
Water Softener Forum, problems, installation and r Kinetico Model 60 Toothed Disk Operation Sep 12, 2014
