Kenmore water softner not drawing brine
Discussion in 'Water Softener Forum, Questions and Answers' started by SHP, Nov 13, 2011.
  1. SHP
    SHP New Member
    Nov 13, 2011
    Maryland
    I have a Kenmore Elite water softner and it is not drawing brine. I have cleaned the venturi and gave it an extra back flush. Does anyone know what else I can do?
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    If the drain flow control is blocked the unit will not draw. Also the rotor, rotor seal or figure 8 o ring can cause it not to draw. If the venturi gasket has a lot of impression from the venturi, the draw will be chocked down. The unit comes with a flow control in the venturi. Remove it and check to see if you have a draw. Place unit on bypass. Advance it to a draw cycle and disconnect the brine line from the valve. Put the unit in service and check for a draw. If you have a draw and than lose it, the drain is restricted.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    there is a link here somewhere to kenmore's equipment or you can slog around their site till you find it. It's very useful but..Mialynette has steered you in the right direction. You can find the break down of kenmore's site though
  5. mialynette2003
    Nov 24, 2010
    Ocala, Florida
Similar Threads: Kenmore water
Water Softener Forum, Questions and Answers Kenmore water softener problem Jan 21, 2016
Water Softener Forum, Questions and Answers No soft water / no salt usage with Kenmore 300 Feb 17, 2015
Water Softener Forum, Questions and Answers Kenmore Water Softener white 1" Disk Nov 27, 2014
Water Softener Forum, Questions and Answers Kenmore 350 watersoftner board fix for free! Oct 4, 2014
Water Softener Forum, Questions and Answers Kenmore water softner Oct 3, 2014
