Junction box in attic mounted on truss support
Discussion in 'Electrical Forum discussion & Blog' started by pex006, Jul 18, 2013.
  1. pex006
    pex006 Member
    Jul 30, 2012
    Pittsburgh, Pennsylvania
    Is it ok to mount a junction box to a roof truss support. They are 2x4 in size. The access to the attic is through a hole in my hallway that I have to get a ladder to go up through it. The junction box will be 10 feet from the access hole.
  2. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    You are doing fine. Secure the box well. Secure the cable or conduit properly. When in doubt, use a few more staples. Ten feet from the hatch is way more than enough. Don't fail to put a cover plate on the box when you are done. Or a light is fine as well. Just keep the cable or conduit well away from the hatch. I seem to remember it is 3'.
    Your picture shows a floor. Keep the cables or conduit behind those jacks and away from the center.
    Current code wants you to install a nailer if your cable is perpendicular to the ceiling joists. 1x3s will do the trick. That is good practice, the cable is nearly immune to damage then. Unless you go after it with an axe. Don't go after it with an axe.
  4. pex006
    pex006 Member
    Jul 30, 2012
    Thanks. I'll make sure it is well away from the floor.
Similar Threads: Junction attic
Electrical Forum discussion & Blog Electric baseboard installation: no junction box behind it? Nov 25, 2016
Electrical Forum discussion & Blog Old Meter Box Junction Nov 9, 2016
Electrical Forum discussion & Blog Romex to THHN conversion in house junction box Oct 2, 2016
Electrical Forum discussion & Blog Hot tub wiring (outdoor junction box) Sep 1, 2016
Electrical Forum discussion & Blog Large junction box Jan 6, 2016
