Jet Pump runs, but not pumping! Help
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jay3129, Mar 19, 2008.
  1. jay3129
    jay3129 New Member
    Aug 7, 2007
    make myers 1/2 HP
    model HJ50D
    My deep well Jet pump sounds normal, but is not pumping much water ,maybe a liter per min. The well is full, it is not losing its prime. I believe it might be the ejector . Or could my pump just not be pumping to capacity. Dont know much any help appreciated
  2. Gary Slusser
    Retired
    The pump must be primed, not a well. You remove the plug etc. on the outlet of the pump and pour water in until it overflows, then cap and start and vent air out the cap until gone and tighten it. Without priming it, you will burn it up. And you can't tell that you did because it sounds 'normal'.
    Or you could have a blocked jet i the pump or if a two line deep well jet pump, then in the j-body in the well. Or you used too much water and the pump sucked air and needs to be primed or the pump is worn out; meaning the impeller.
  4. jay3129
    jay3129 New Member
    Aug 7, 2007
    Yes I know the pump needs primed , not the well. I meant to say it does not lose its prime at all, the 2 lines(deep well) are full of water. There is No air in the pump. The pump runs i, theres water in it, its just not going anywhere. I have suspected the ejector(or j-body), just didnt want to replace cause its a pain to get to. Have taken the pump apart and the impeller looks brand new.
Similar Threads: Pump runs
Pumps and Tanks Well Forum & Blog. Water is life. Pump runs continuously while water is on. Mar 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump does come on and runs until pressure gauge reads 70. Aug 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump runs then all of sudden stops Mar 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump only runs when I push the contacts together Feb 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
