Jet pump control valve adjustment
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by gardner, May 12, 2009.
  1. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    I have a Red Lion convertible shallow well jet pump. It is set up to pull water from a lake, about three feet below the level of the pump, through a 1-1/4 polyethylene line. Other than a vacuum leak at the inlet barbs that I am working on, I think everything is working okay.
    The discharge goes uphill against a 20 psi head to the main building where we want about 40 psi. From there another 15 psi uphill is a holding tank that supplies water when the generator that powers the pump is shut down.
    This pump (and probably many like it) has as valve or adjuster next to the discharge, opposite the priming hole. The manual describes this as a "control valve", but says little more about what it controls, how to adjust it, or why.
    Why would I want to mess with this, and what would I do to adjust it optimally? My guess is that this allows me to make a volume/pressure trade off somehow. Where can I look to understand the ins and outs of messing with the control valve?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    That adjustment is probably a manual backpressure regulator. It's used to in the case of the manual regulator to get the prime. Once primed, it's opened up all the way. It's only used on a deep well system. On a shallow well system like yours, it's left open all the time.
    A jet pump can make a max of 60 psi in most cases. I don't know what your referring to using the term head. Head is vertical feet. Pressure is head X.433.
    bob...
Similar Threads: pump control
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Confused about pumptec and control box Nov 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Connected 115v pump with 230v control box Jun 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump System Control Issue Jun 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Control box for pump necessary? May 18, 2016
