Issue with Rain Bird ESP-me controller
Discussion in 'Irrigation / Sprinkler Forum' started by aguaman, Aug 29, 2013.
  1. aguaman
    aguaman New Member
    Aug 29, 2013
    Miami
    Hello,
    just got an irrigation system put in with a Rain Bird ESP-me controller. I have 4 zones with zone 4 set up for a future veg garden so it's not in use. The controller is programmed to run 5 minutes every day starting at 8 am. The issue is this: I noticed that it goes on 5 minutes in zones 1 thru 3 and then back another 5 minutes zones 1 thru 3 and another 5 minutes for the 3 zones. It is programmed to run 5 minutes so why is it really runnig 45 minutes in total?
    This is very puzzling to me. I reset the controller twice and programmed it all from scratch but still runs a total of 45 minutes.
    Any help with this is greatly appreciated. :D
  2. BRD
    BRD New Member
    Jun 22, 2009
    irrigation contractor
    northeast
    You have probably confused run times with start times. For prog. A, set each individual station with the run time you want for each (5min.) Then go to program start times and assign just ONE start time. Each zone will run in sequence one right after the other until done. Start time 2 and 3 should be "off".
  4. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    You have to read the setup instructions and understand them, to be able to follow them. Once you understand it, it's fairly simple to do.
    In most cases, these timers are much more than what homeowners actually need. Some of the features are never used, but they are there.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    You mean read the Manual ?
    What a concept.
    Good Luck if it is in plain English, Now a Days.
  6. dj2
    Aug 13, 2013
    California
    Haha, it's true...
    I have helpers, to whom ENGLISH is not their first language, but they manage to read, understand and execute instructions.
    Ah, I forgot, the instructions have a Spanish version on the other side.
  7. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    this is ALWAYS an operator error
    pro controllers never start a zone, they start a program - the error comes when someone mistakenly believes they have to assign a start time for each zone of the system
    only one start time - cancel the second and third start times
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    More like Operator Overlook.
  9. aguaman
    aguaman New Member
    Aug 29, 2013
    Miami
    Re-reading the manual and based on BRD's comments, I see that the SET WATERING TIMES is to program the starts times of a PROGRAM (or PROGRAMS) and NOT the zones. I had 2 and 3 thinking them as zones but the controller took them as programs 2 and 3. After 1 ended, program 2 would start and then 3. That's why it ran 3 times. I set to OFF the PROGRAMS 2 and 3 and sure enough it only run a total of 15 minutes (5 minutes per zone).
    It is running fine now as I wanted it. Thanks for all the replies and to BRD for hitting the nail in the head.
  10. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Cool Beans. Thanks for the report.
    Enjoy.
  11. Recon0321
    Recon0321 New Member
    Oct 20, 2013
    Arizona
    This seems to be explained in a confusing manner. The station start times have to be set according to your desired start times for each station to run. It seems the simple answer to aguamans question would be to ensure that you only have one program running (A or b or c).
  12. Wet_Boots
    Mar 23, 2007
    Metro NYC
    THERE ARE NO STATION START TIMES!! THERE ARE ONLY PROGRAM START TIMES!!
    Repeat this until you are certain you will never spread misinformation about this aspect of lawn sprinkler controller programming.
  13. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Sorry to have disappointed you with my post.
    I think the problem has been solved.
    I Love when that happens, thanks to www.terrylove.com.
  14. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Good stuff.
    For the future, when you do have your vegetable garden planted, you will want to water it less often - maybe only once or twice a week. That is where you can set up your system so that Zone 4 (veg garden) runs for, say, 30 minutes every Sunday, and program this in Program B (assuming the rest of the lawn is watered in Program A). That's the beauty of having multiple programs -- you can run a zone, or several zones, on a different schedule from the rest. You may already know this.
  15. Leonard Sorin
    Leonard Sorin New Member
    Apr 19, 2017
    IASI, Romania
    Hello,
    I buy from AMAZON a ESP-4ME/ 230V / WiFi + LNK controller a few days ago, and it’s works OK a few hours until I put in the right position in the garden. The router signal was too weak, no connection, so I pushed the LNK button for 1 sec to generate a AP to work only with iPhone7. The LED light begins with red and green, and after that only red flashing. I pushed again the button, but no hot spot begin, and the LED light also red flashing. I pushed and holded 5 sec for restore factory settings, and after that, red and amber light flashing continuously again, no effect if I pressed again for AP start. I stoped the power supply from a few minutes to many hours, but no effect. I reset also the ESP-4ME controller but no effect. I mention that ESP-4ME controller works good, only LNK module has a problem. Any help with this is, greatly appreciated, without sending for warranty in US for beginning. Thank You.
Similar Threads: Issue Rain
Irrigation / Sprinkler Forum Rainbird ESP-me Start Time issue Jun 24, 2015
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Shallow well pump issues Sep 24, 2016
Irrigation / Sprinkler Forum Sprinkler Issue Jul 2, 2016
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
