Is my pressure gauge shot?? low water pressure.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by help4steveo, Apr 13, 2010.
  1. help4steveo
    help4steveo New Member
    Feb 3, 2008
    Our house is 28 years old. deep well pump works fine, pressure set at 40/60 and bladder about 38.
    I've noticed decreasing system pressure at the faucets/shower heads....probably over a 6 month period.
    Some things I've thought of: Replace pressure gauge, buildup of crud in pipes over 30 years, ?? any other thoughts? Thanks..very useful forum!!!!
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Who knows! I'd suspect buildup in the 30 year old pipes. It could be clogged or buildup in the faucet and shower heads. If there are filter screens in the faucets and shower heads I'd clean them with some CLR. I'd also check the screens in the washing machine hot and cold water hoses as well.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I wondered about my galvanized pipes so I replaced a couple of sections to see what the inside looked like. Surprisingly, my 1962 piping is clean as a whistle on the inside.
    I would start by monitoring the gauge pressure while a hose bib or tub is running- will the pump keep the gauge pressure up with the demand?
  5. masterpumpman
    Mar 26, 2007
    Virginia Beach, VA
    First I'd replace the guage, then do your test. Your pump should keep the pressure up with the demand, however this depends on the well supply and the pumps ability to supply sufficient water flow.
Similar Threads: pressure gauge
Pumps and Tanks Well Forum & Blog. Water is life. New Pressure Gauge Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump does come on and runs until pressure gauge reads 70. Aug 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. No Water - Pressure Gauge At 70 Apr 4, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure good gauge but drops Jul 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. I got a pressure gauge. Long story. Not having a problem. Jun 6, 2015
