Is it possible to over filter?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by gebishop, Sep 27, 2010.
  1. gebishop
    gebishop New Member
    Sep 27, 2010
    North Georgia
    I have lived in my home for 18 years and always had a Big Blue whole house filtration system. I use a string wound filter first, followed by a sediment filter. Yesterday my water pressure dropped to nothing if I was running more then one appliance that required water . For example, I flushed the toilet and turned on the shower and had a small stream of water coming from the shower head. After the toilet tank refilled the shower head had normal pressure. It also took my washing machine forever to fill. I put in fresh filters the first of September 1 and purchased filters that I thought would last for 6 months: Culligan RFC-BB 10" Big Blue Water Filter RFC-BBS and Aqua-Pure AP814 Rust, Dirt, Sediment Water Filters. I have not used filters in the past that lasted more then two months. Today, I went into my crawl space to check my filters since my water pressure is still so low. The string wound filter looked fine. The second filter ( Micron Rating: 25 Micron, Dimensions: 9 3/4" x 4 1/2", Carbon, Filter Life: 10,000 gallons or 6 months per filter, Culligan Filtration Level 4 - Premium Filtration) had mud in the canister and on the bottom of the filer. I have never had this problem. Have I used a filter that is too strong? Any advice would be helpful.
    Thank you
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I have found that carbon filters tend to cause a drop of pressure in the line.
    25 microns is about the size of a white blood cell. 1 mm is 1000 microns.
    If you use too fine of a filter it will clog in a short time and cause the problem you now have.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    You should check and see if your pressure tank still has a bladder or diaphragm intact. Filters are great for saving you from a slug of crud when the bag breaks.
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    The better the filter, the slower the flow! Filters are great where needed but they will restrict the flow. Yes, you can almost filter yourself out of water.
Similar Threads: possible filter
Pumps and Tanks Well Forum & Blog Possible Replacement of Pressure tank Needed Nov 19, 2015
Pumps and Tanks Well Forum & Blog Well head cover impossible to get off Nov 13, 2015
Pumps and Tanks Well Forum & Blog Best pump for hard water also, please review our setup & suggest other possible improvements Oct 22, 2014
Pumps and Tanks Well Forum & Blog Septic Tank-possible problem. Sep 13, 2013
Pumps and Tanks Well Forum & Blog Issue possible grinder pump?? Feb 21, 2013
